firmware konica 7165
  • roniirawan
    • Nov 2008
    • 15
    hi...
    i need firmware for konica 7165
    can anybody help me..
    thanks
    roni.irawan@gmail.com
  • DallasTech
    • Feb 2007
    • 119
    Originally posted by roniirawan
    hi...
    thanks
    It's on the SSD page, which firmware do you need? I might be able to email it to you.
    • carneage
      • Oct 2009
      • 35
      Firmware konica 7165
      hi there i also need the firmware and any software that goes into the konica 7165 as both of the hard drives on my konica have crashed, if you could email me or Pm me that would be great
      carneage@hotmail.com
      thanks
      carneage
      • pepper38_cnd
        Field Service Manager
        • Aug 2005
        • 1075
        The main body HDD contains no software, the IP-511A HDD must have the system code preloaded on it before installing in the IP this can be done with a ghost image.
        Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
        Now into Ip TV KODI Boxes
        • roniirawan
          • Nov 2008
          • 15
          system software for ip 511 / pi 6500e
          hi dallastech
          i need firmware for pi 6500e / ip 511 for printer controller because my printer controller can't ready but on the screen appears system booting please wait....
          thanks
          • pepper38_cnd
            • Aug 2005
            • 1075
            Have you tried the Restore feature? If the HDD is ok but the System code is corrupt the Restore will reinstall the Original system code of the IP-511.
            • carneage
              • Oct 2009
              • 35
              the copier has taken a hit in transport and has killed its hard drive. also on bootup it heats up the fuser and hangs in the screen booting please wait a while.... and then nothing
              • carneage
                • Oct 2009
                • 35
                where could i get hold of a Ghost or any software for the ip511??
                • totoket99
                  I have the Ghost Images for Both a 6Gig and 20Gig drive.
                  However, you need to make sure that your Nic firmware is above 6.30.
                  • carneage
                    • Oct 2009
                    • 35
                    i have 6.28d where would i get the latest update... also how can i up the font list in this IP-511??
                    • totoket99
                      Are you able to get a configuration and Nic Page printed? If so send them to me. I have all the nic and H/D firmware available.
                      DESCRIPTION:
                      Unit will not initialize after upgrading the system code of the IP511. SOLUTION ID:
                      130743
                      SOLUTION:
                      CAUSE: The IP511 NIC firmware should be upgraded before the IP511 system code.
                      SOLUTION: To clear the error, it is recommended to temporarily downgrade the IP511 system
                      code to the previous version. Update the NIC to the desired level and then update the IP511
                      system code.
                      • carneage
                        • Oct 2009
                        • 35
                        i have a print out every time the printer starts up ... is that the one if so tell me a email add and i will forward
