7085 finisher problem
  • smiley
    • Aug 2008
    • 616
    hi guys i have 7085 with 4m on counter but still work great.then i try to install 7075 finisher i thought they are same.when i attach it it doesn't work or even initialize i took another finisher but still dont work.any suggestion i need help please.
    there is no glory without sacrifice
  • Luther
    • May 2006
    • 682
    The 7085 uses th FS-111 and FS 211, THE 7075 USES THE FS 108 AND 108B
    • smiley
      • Aug 2008
      • 616
      thanks for the quick response luther.i still have a problem my adf didn't read 8.5x11 it read as A4 how can i make it read the 8.5x11 as 8.5x11 not a4.thanks
      • Luther
        • May 2006
        • 682
        Send me your email address and i will send you the adj.
        • smiley
          • Aug 2008
          • 616
          hi luther this is my email neil_lcm@yahoo.com thanks.
          • Luther
            • May 2006
            • 682
            Smiley i sent the adj section of the manual, it is page 69 (edh size adjustment) good luck
            • smiley
              • Aug 2008
              • 616
              thanks luther i will try it thank you soo much.
              • BUSHWACKER
                • Aug 2008
                • 25
                konika minolta cf9001
                Hi Guys, have a problem that the paper/board is jamming as it hits the fuser unit.
                Have checked the locating gear at rear of machine seems ok.
                Have removed back panel and checked that everything is turning, all
                seems ok.
                When machine is switched off and the fusing unit is manually turned everything seems to be locating properly.
                Any Ideas
                Sorry for posting query here but i cannot find where to enter new postings
                Help in that regard would also help
                thanx
                Regards
                Bushwacker
                Durban
                Last edited by BUSHWACKER; 05-04-2009, 01:00 PM. Reason: probably not in correct posting
