Konica Minolta C350 RESETTING FUSE PROBLEM
  • arriva1
    • Apr 2007
    • 66
    I was wondering on the Konica Minolta Bizhub C350 if the copier isn't asking for the transfer belt can the fuse still be reset?? Because i tried resetting it with a .315 and 1/2 amp fuse and it won't reset---any suggestions??
  • simplex
    • Mar 2009
    • 8
    I would suspect those fuse ratings are too high. I usually use either 50mA or preferably 80mA.
    You can definitely reset part way into service life, I often do this to save return calls.
    • arriva1
      • Apr 2007
      • 66
      Do you know where I might be able to find that 50MA or 80MA fuse?
      • simplex
        • Mar 2009
        • 8
        Here in the UK, I order them from CPC Farnell, or Maplin.
        I'm not sure what component suppliers you have in the states, but it should be 50 - 80mA quick blow glass cartridge.
        Come to think about it, Katun may sell them, as they are used in a lot of toner cartridges, & they sell the reman. kits.
        Hope this helps.
        • DadO
          • Dec 2007
          • 404
          I used 100ma or 0.1A and it worked but if u find something lower then 100ma, use it since 100ma is on edge
          • Bizhub
            • 147
            Don't fit to high a rating fuse as you will damage the PWB MC.
            80ma glass fuse's are everywhere but try RS in the states
            Good Luck
            • pepper38_cnd
              Field Service Manager
              • Aug 2005
              • 1075
              The OEM fuse is 1/16 A or 62Ma I use 63Ma as for some reason they are about 1/4 the price of 62Ma. But the advice you have been given is correct too high a rating is very risky ( board damage can occur ). I can supply you the 63Ma fuses if you need them.
              Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
              Now into Ip TV KODI Boxes
