Minolta c452 Gear Help
  • kleankopy
    • Feb 2016
    • 114
    We mostly do Ricoh so dont want to buy a parts manual for this old machine but trying to help a small local school. The back white gear is all hollowed out. Does anyone have it or a part number?
    The front gear has a c clip so not sure what keeps that gear on or if its part of an assy.
  • wilez
    • Jan 2011
    • 55
    Re: Minolta c452 Gear Help
    No longer have parts for that box. But the first I had to replace it I matched it with gears I stripped from a ricoh c5501. typically around the duplex or paper feed drive use gears similar to that one.
    Looked in the 4 series color manual not sure part number will match. Good luck.
    https://t.me/pump_upp
    • Tech09
      • Apr 2020
      • 144
      You would be better off replacing that whole assembly, Paper Exit belt drive assy A0P0R73611. It's going to be more than just that one gear that's bad.
      • kleankopy
        • Feb 2016
        • 114
        Thanks for part number. I was thinking it was an Assy since didn't look like that gear came off.
        • allan
          RTFM!!
          • 5462
          This is where 3D printed gears would be handy.
          Whatever
          • Synthohol
            Certified Konica Expert
            • 5814
            superglue, corn starch and a drill.
            did it a few times for that assy.
            learned to do it from the old Di and EP series LCC lift gears.
            the d cut holes in the old gears used to round out but packed with a slurry of CS and SG ad that gear outlasted the machine.
            its poor mans ceramic cement. it can be filed, drilled, shaped and sanded.
            • kleankopy
              • Feb 2016
              • 114
              Found the assy on ebay for 40.
