C500 SC29-03 Error
  • JayPro
    • 10
    C500 SC29-03 Error
    Hey Guys, I tried everything in the SM, cleaned all areas, and still cant deal with this voltage problem.
    Any light to shed?
    Jay.
  • time2fly
    • Jul 2008
    • 134
    Better get a Tech. to help you.
    • time2fly
      • Jul 2008
      • 134
      what does the SM say
      • JayPro
        • 10
        Two techs are on it.....just checking if anyone had the same issue, cause after all diagnostics, the error still there....
        • JayPro
          • 10
          1. Enter the 36 mode.
          2. "36 mode menu screen"
          Press the [1. Process adjustment] key.
          3. "Process adjustment mode menu screen"
          For the process adjustment, there are the following
          items provided:
          [1. High voltage adjustment]
          [2. Drum peculiarity adjustment]
          [3. Sensor output adjustment]
          [4. Exclusive paper setting]
          [5. Recall standard data]
          4. Press the key of an item you want to adjust.
          5. Press the [PREVIOUS SCREEN] key to return
          from each of the adjustment screen to the
          "Process adjustment menu screen."
          • Vesigoth
            • Mar 2008
            • 133
            items provided:
            what about a bizhub c500 with an sc-2701
            • Vesigoth
              • Mar 2008
              • 133
              c500 with sc 2701
              c500 with sc 2701.? please help
              • JayPro
                • 10
                sc27-01
                3. "Process adjustment menu screen"
                Press the [2. Drum peculiarity adjustment] key.
                4. "Drum peculiarity adjustment menu screen"
                For the drum peculiarity adjustment, the following
                items are provided:
                [1. Blade setting mode]
                [2. Automatic drum potential adj.]
                [3. Automatic gamma adjustment]
                [4. LD bias adjustment]
                [5. Automatic developer charge]
                [6. L-detect initial auto. adj.]
                [7. Initial drum rotation]
                5. Press the key of an item you want to adjust.
                6. Press the [PREVIOUS SCREEN] key to return
                from each of the adjustment screens to the
                "Drum peculiarity adjustment menu screen.
