Remote Panel via Web Browser Konica Minolta 8 series
  • Jinn
    • May 2023
    • 122
    Hi,
    I want to access MFP's control panel remotely via Web Browser.
    In Admin Mode > Network Settings > Remote Panel Setting > Remote Panel Server Setting is not showing?
    Is there any software switch to enable this function?
    OR Have to update a special firmware for this one?
    Please advise!
  • tsbservice
    Field tech
    • 8011
    Re: Remote Panel via Web Browser Konica Minolta 8 series
    Originally posted by Jinn
    Hi,
    Please advise!
    Do you have CE password removed?
    In other words when you hit - S 0 0 S 0 1 will it enter service mode without password?
    • elmaligno
      Expert technician KM
      • Oct 2009
      • 302
      Hi,
      Please advise!
      To access the machines remote panel remotely from PC on the same network you will
      need to set or check the following three items.
      1) The CE password is enabled.
      Service Mode> Stop 0>C (CE Authentication) Set to ON.
      Note: The CE Authentication button will not be displayed when the remote panel
      (Server Settings) is set to ON.
      2) Issue and install the self-signed certificate from device certificate setting under
      security settings of Page Scope Web Connection. (Details on next page)
      3) Set the Remote Panel Server setting to ON
      Admin mode > Network Settings > Remote Panel Settings > Server Settings.
      Set Use to: ON
      Access the remote panel by typing the following address into the web browser.
      https:// MFP IP Address :50443/panel/top.html
      Field technician since 1994
      • elmaligno
        • Oct 2009
        • 302
        Hi,
        Please advise!
        Creating a Self-Signed certificate using Page Scope Web Connection
        1) Log onto to page scope web connection as an administrator.
        Note: Standard password is [1234567812345678]
        Click on the security tab
        Click on new registration
        Create and install a self-signed
        certificate is already select, so
        just press ok.
        Complete all the fields; the
        information in this picture is
        an example. The information
        can be whatever, Just make
        sure the email address is the.
        Format of an email address
        and validity period is 3650.
        Click ok and the certificate
        will be created and installed.
