Remote Panel via Web Browser Konica Minolta 8 series
  • elmaligno
    replied
    Re: Remote Panel via Web Browser Konica Minolta 8 series
    Originally posted by Jinn
    I want to access MFP's control panel remotely via Web Browser.
    In Admin Mode > Network Settings > Remote Panel Setting > Remote Panel Server Setting is not showing?
    Is there any software switch to enable this function?
    OR Have to update a special firmware for this one?
    Please advise!
    Creating a Self-Signed certificate using Page Scope Web Connection
    1) Log onto to page scope web connection as an administrator.
    Note: Standard password is [1234567812345678]
    Click on the security tab
    Click on new registration
    Create and install a self-signed
    certificate is already select, so
    just press ok.
    Complete all the fields; the
    information in this picture is
    an example. The information
    can be whatever, Just make
    sure the email address is the.
    Format of an email address
    and validity period is 3650.
    Click ok and the certificate
    will be created and installed.
  • elmaligno
    replied
    Please advise!
    To access the machines remote panel remotely from PC on the same network you will
    need to set or check the following three items.
    1) The CE password is enabled.
    Service Mode> Stop 0>C (CE Authentication) Set to ON.
    Note: The CE Authentication button will not be displayed when the remote panel
    (Server Settings) is set to ON.
    2) Issue and install the self-signed certificate from device certificate setting under
    security settings of Page Scope Web Connection. (Details on next page)
    3) Set the Remote Panel Server setting to ON
    Admin mode > Network Settings > Remote Panel Settings > Server Settings.
    Set Use to: ON
    Access the remote panel by typing the following address into the web browser.
    https:// MFP IP Address :50443/panel/top.html
  • tsbservice
    replied
    Please advise!
    Do you have CE password removed?
    In other words when you hit - S 0 0 S 0 1 will it enter service mode without password?
  • Jinn
    started a topic Remote Panel via Web Browser Konica Minolta 8 series
    Please advise!
