bizhub 200 c2557
  • CCS@yahoo
    • Mar 2009
    • 14
    bizhub 200 c2557
    bizhub 200 c2557 code?
  • BR549
    • 108
    Replacing drum without replacing developer would cause it. If that is the case, replace developer and quickly run F8.
    Service manual says ATDC sensor failure.
    Bad ATDC sensor or wrong (Di3510 series) sensor.
    If thats not it replace PWB-A
    • CCS@yahoo
      • Mar 2009
      • 14
      bizhub 200 c2557
      much appreciated
      • Si@danwood
        • Mar 2008
        • 154
        Set ATDC value to approx 80.Should run ok without replacing the developer,but make sure you run at least 100 test copies afterwards just in case!!
