Bizhub 163 total count reset
  • freixi
    • May 2009
    • 53
    Hello the team,
    1.is es possible reset the total counter from bizhub 163?
    2.Y have the programmer from programing the DS2432
    but with which software can I use it to program?
    is es possible wih the poniprog?
    Sorry my english, i from Germany.
    Thx for all.
    Freixi
    German.
    Hallo das Team, ist es moeglich den bixhub 163 den gesammtcounter zurueckzustellen?
    desweiterem suche ich die software um den DS 2432 chip zu programmieren. Den passenden programmer habe ich bereits.
    Gehts mit Poniprog?
    Danke im voraus
    Freixi
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    I,m not sure what programming the the DS2432 has to do with the Bizbub 163. But the answer to your question is, no you cannot use PonyProg to program the DS2432 you must use a 1-Wire type program and programmer.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • freixi
      • May 2009
      • 53
      Thank you for your reply.
      The bizhub 136 is the only problem that I count on 000000000 wishes.
      I have the 1-wire program but a demo version and I can not write.Kann someone the 1-wire program receive? would be very grateful.
      Many thanks in advance
      freixi
      • ni311
        • May 2008
        • 658
        To reset the counter of your Bizhub 163, you need a new NVRAM. Do a search, I saw a few people selling these things.
        Konica Minolta Error Codes - Explanations and Solutions
        • freixi
          • May 2009
          • 53
          Thx for reply
          NVRAM ? Wahts tis??lol... is es a new hardware, or the chip?
          when there is a new chip is what is inside the original?
          Can the man re-program?
          Thank you
          freixi
          • kesserling
            NVRAM
            The nvram is on the back of your copyer
            after take it and send me these nvram and before print the counter
            • freixi
              • May 2009
              • 53
              Hello.
              Thanks for the reply .. will send bad, I'm in Germany and portugal and do not know where the NVRAM is. is in the soket?
              I still search the 1-Wire Software for a DS2432 to writen, I have a serial programmer.
              Thank you very much
              Freixi
              • JustManuals
                • Jan 2006
                • 9838
                For what legitimate reason would you want to reset the total page count?
                In civilized countries doing this is the same as resetting a car's odometer, highly unethetical and illegal.
                Paul@justmanuals.com
                • freixi
                  • May 2009
                  • 53
                  Hello
                  ilegal is the resetting of the tonner chips.
                  The copier consists entirely of new parts, the electronics is another copiers have been installed. that is why I wanted the set to zero
                  sorry if it has been misunderstood
                  Thank you
                  Freixi
                  • JustManuals
                    • Jan 2006
                    • 9838
                    Oh, so the parts you installed came from a copier with a zero count?
                    • freixi
                      • May 2009
                      • 53
                      new parts
                      freixi
                      • Kmdurrin
                        Copy/Print/Network Tech
                        • Dec 2008
                        • 132
                        So you installed some new parts in the machine, and now you want it to appear as a new machine? That really doesnt sound like a good idea. Are you trying to sell this as a brand new machine?
                        Parts: Its what your copier craves!
                        • freixi
                          • May 2009
                          • 53
                          no, I will not sell, that's my copier, I have the parts from a company bankrupt (konkurs) is gone.
                          I have another auction (color copier) and the software looking for a ton of chips in order to write. The dumps, I have already for the DS2432, the only software I have so far can not find. I have a Serial programmer.bin very grateful to me because if someone can help.
                          Thank you very much
                          freixi
                          • freixi
                            • May 2009
                            • 53
                            can anyone help me with the 1-wire chip software program for the DS2432? If yes please send an email to
                            c-silva-alberto@clix.pt
                            Thank you very much
                            Freixi
                            • abilashvk
                              • 61
                              dear friend,
                              what meant by NV-RAM is a small 8 leg parameter chip fixed on the PWB-MFP,ie.. the pwb with USB port.It can be easly removed as its placed in a socket. this chip contains model no.,ATDC value etc. OR you take out the parameter dhip from biz 163 ,place in a biz 162 and put on the machine,It will cure chow C03ff(model err),c0f32 which U can overcome from Ser. mode. After that fix it back to 163. Once that worked.
