Konica Minolta b420/500 error C-3801
  • Bullet71
    • May 2009
    • 29
    Hi does anyone have a solution to this code as we have a few machines giving it. I know its for the fuser temp and all thermisters are clean.
  • tech51
    • 846
    The temp sensors usually cause this code but before you replace them, make sure you have the correct upper roller fitted. I chased this problem on a 420 for ages before I realised a previous tech had fitted a 500 roller!!
    Hope this helps..
    • harry2007
      • 52
      code
      I had the same problem when web roller was finished.
      But after I changed the web roller-code reappears .
      So,check the web roller. If it's ok - change :FIXING SENSOR ASSY
      50GA -5440
      http://copierservicereset.com
