Drum unit for Nec IT3530
    • 30293
    will a drum unit for a bizhub 350 work?
  • Kmdurrin
    Copy/Print/Network Tech
    • Dec 2008
    • 132
    The IT3520 crosses with a Di3510, if that helps
    Parts: Its what your copier craves!
    • manuelcorrea
      • May 2009
      • 46
      you can use a dr310 and you must also change developer dv310 also run f8
