C5500
  • Biffo
    • 6
    C5500
    Any help or advice much appreciated
  • oscar
    • May 2010
    • 45
    Re: C5500
    Managed to solve?
    • tsbservice
      Field tech
      • 8020
      Re: C5500
      Originally posted by oscar
      Managed to solve?
      Probably not...mainly because it's DEAD and BURIED for some good 10+ years
      • Biffo
        • 6
        Re: C5500
        Managed to solve?
        This was along time ago...
        From memory and checking the service record, I think it was solved by replacing the encoder and PS75 and PS74 belt 2 and belt 1 driven off m8. This motor drives the belt and waste toner mechanism which was also blocked.
        Hope this helps.
          Re: C5500
          Hope this helps.
          well I guess 11 years late in the update is better than none at all.
          • Synaux
            • Mar 2012
            • 1224
            Re: C5500
            Hope this helps.
            My man, you have made 6 posts in total since you joined in 2008 and you promptly respond to this post?
            You sir are a legend!
            *tinfoil-hat engaged*
