Are you needing the part numbers? I have had to replace these before and I recommend also replacing the connector on the fuser. You can't order just the connector, it comes with the harness.
The part number for the fuser connector is 1155-6817-01.
I hope this is the correct number for machine side connector is 1155-6815-02, the picture isn't real clear if this is it, but I do know some of the connectors plug into the SSR's.
