Oce CS665 // KM C6501 Long Paper Softswitch
  • resolute
    • 28
    Can someone give me the detailed softswitch dipswitch setting to enable long paper mode (ie. 1200mm//47.25"). My service tech can't seem to get that info.
  • Si@danwood
    • Mar 2008
    • 154
    Not a 100% sure there is one
    • random
      I only know of a patch for the Creo, it hasn't been marketed by us so maybe it's a myth.
      • sbillis
        • Nov 2008
        • 95
        you can do that but I don't have that info now.
        you can send for print 1200mm one by one (<600mm up to 10 >600mm one at a time)
        be patient please.
        • sbillis
          • Nov 2008
          • 95
          try dipsw 10-0-0, 10-1-0
          • Si@danwood
            • Mar 2008
            • 154
            why would disabling the hard disk image enable banner mode?
            • prakashshetty_thane
              • Jan 2011
              • 7
              Try and change DIPP SW setting 10-0-0 to 10-0-1 to enable banner mode.
              Bypass tray is a must and U can feed only 1 paper at a time and cannot feed another paper unless the first paper has exited the m/c.
              Time consuming but effective..
              No need to disable the HDD.
              • seniortech
                • Dec 2007
                • 180
                These are the settings you need for Banner printing:
                Set DIP-SW 10-0 to 1
                Set DIP-SW 10-1 to 0
                Paper is fed via bypass, I have two of these machines that are only used for banner printing, works well without problems.
