BIZHUB C353
  • thuo
    • 155
    BIZHUB C353
    i have a bizhub c353 which prints and copies with a solid yellow background on copies.
    urgent .please assist
  • tech51
    • 846
    try swapping the print heads ie yellow with cyan and see if the fault transfers.
    • ivovb
      • 695
      Affirmative. I have had the same problem on C253. Culprit was print head (laser unit for yellow).
      BR
      I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
      • thuo
        • 155
        I have swapped the print heads and confirmed the yellow print head is the problem.can print heads for bizhub C203 be replaced in bizhub c 353
        • thuo
          • 155
          • JSC
            Gimp
            • Dec 2006
            • 618
            No, C203 & C253 are the same C353 is different
            The gene pool could use a little chlorine.
            • thuo
              • 155
              Thanks for your assistance
