Monilta Di551 - print/scan/email
  • kuby
    • Oct 2007
    • 1409
    Customer wants to have this setup to scan and print and to do email. What do I need or need to do to set this up. I see the setting for email and IP address. It looks like it has a network card, do not know if it is hot. (not on a network, and have not been back with my computer to see if it works) What do I look for, Thanks
    Ronald
  • DonEMeyers
    Minolta Di551 print/scan/email
    You will need to install a Pi6500e Fiery controller to do what you want.
    The nic on the machine is for the WEB interface.
    • buster68
      • Nov 2008
      • 181
      Along with that Pi6500e you will need the PS3 Scan kit with a Hard Disk Drive.
      • TheOwl
        • Nov 2008
        • 1732
        You will find that there should be 2 network cards on this machine if you already have a controller installed.
        One on the left hand side of the machine for machine diagnostics, address book, tandem printing etc. (possibly covered by a silver sticker)
        One on the rear of the machine on a separate box so to speak.
        The one on the rear of the machine is the one that you need to use. When you say scan, print and EMAIL, what are you looking for with the email side of things?
        If you already have the controller installed, then push the button that scrolls through your copier modes until you get to print. You should then be able to get to the controller menu from there.
        • kuby
          • Oct 2007
          • 1409
          Anyone have the part numbers for these kits, or have these kits and what I need to set it up.
