C253 - C3201
  • bizhubc253
    • Aug 2025
    C253 - C3201
    Got a C253 that throws up a C3201 fuser motor error.
    It has a had a replacement fuser motor (two actually), a fuser unit (a further two), a frimware upgrade and a replacement main pcb.
    After the last replacement of parts it has worked ok for about a month it has come up with the C3201 error twice in that period but once the errors were reset the unit worked fine. Now it has packed up again and the error will not clear.
    Any ideas
  • abilashvk
    • 61
    hi friend,
    What if Ur Power supply PWB not backing the load?Just a curious enquiry.
    • DCPS
      • Mar 2008
      • 116
      Yep. It's a common problem on them and it's the Power Supply. I had 3 machines until now with this symptom.
      • bizhubc253
        Thanks will give a power supply a go.
