C352 Print problem
  • ASE1989
    • Jul 2025
    C352 Print problem
    Have a Konica-Minolta C352 BizHub , with 45000 copy's on counter, that prints a "faint" copy in black/white. Same condition when printing in color.
    Put in a new black drum in Jan. 2009. Then 2 weeks ago this problem arose. Got another black drum since the local service tech said he could find no problem and thought it was bad. Installed new drum and problem was solved until last Friday.
    Same problem and service tech does not know what is wrong.......
    He said unit may have a bad transfer belt but not sure.....Also maybe firmware issue, not sure..........
    Do any of you have an idea of what has gone out or what the issue is?????
  • mascan42
    • Oct 2008
    • 484
    I don't think I understood the problem. Is it only the black that's coming out faint, or all colors?
    • JSC
      Gimp
      • Dec 2006
      • 618
      Could be the toner add clutch, i had one do somthing very similar. How many copies between image units being fitted?
      The gene pool could use a little chlorine.
      • ASE1989
        Faint copies happen in both black and color. It is very hard to see image. The black imaging unit had approx. 4000 copies on it before it went out. The replacment black imaging unit has less then 1000 copies on it. We have tried to clean the corona wires. The copier scans, faxes just find.
        There are no error codes, either...................
        Thank you for the replies!!!!
        • Kmdurrin
          Copy/Print/Network Tech
          • Dec 2008
          • 132
          Are you using OEM toner?
          Parts: Its what your copier craves!
          • ASE1989
            Yes, all toner and imageing units are OEM.
            Had a 3rd tech come in yesterday................He was here for 5 minutes, $175.00 and problem fixed.
            He said he ran a inialization and stabilzation on the unit. It now copies as it should.
            I do not understand what he did and why!!!!! Can anyone explain????
            Thank you to those who responded..........................
