Hi. One day after replacing the cyan drum unit I have the print error that you can see in the attached file. The red arrows show the error. I think that the drum is not well cleaned by the blade and it is repeating the image that just print. This is a new drum unit and I want to be sure before change it again that it is a drum unit problem. Any ideas? Can I change the cleaning blade of the previous drum to this one? Is in fact a bad cleaning blade or the whole unit drum is defective? Some one has have this problem before?
Thank you for your help.
