New MFP board fitted
  • mailderrick
    • Mar 2010
    • 131
    #16
    Re: New MFP board fitted
    Originally posted by joneze
    The original problem was that the first page of a set has background on the lead edge of the first copy. This is a know problem from Konica Minolta and is cause by the said board. Now when we fit the original board back the machine starts fine which tells me its not a NVRAM issue. But i will be trying all sugestions mention today.
    Many Thanks
    I have just had this same exact problem and i had a heck of a time trying to figure it out. It is a board problem but it is actually the Printer Control board(specifically ICP5 on the board burns out which you can test with an ohm meter). I took a bad board and replaced the resistor and to my surprise i was up and running like a brand new machine. I hope this helps save someone the headaches i went through to figure this out - also with a little support from some good techs and this forum.
    Derrick
