C250 error
  • Shannon Springer
    • Aug 2025
    C250 error
    "On the main display of my printer I have the message; "Direction for this OHP size is not supported please change direction or set paper size larger than 8 1/2 X 11"
    I have removed all paper from all trays and cycled the power. The message is still there. Any ideas?
  • Specilist KVN
    • Sep 2008
    • 79
    Rotate the sheet 90 degrees.
    You need to grip it from theother side, most likely the 11" side.
    OHP is not a standard stock and needs to be handled differently
    • Shannon Springer
      It seems that our accountant was trying to print Checks from the bypass tray and unknowingly set the paper setting to OHP. All is well now Thanks
