Bizhub C353 Syntax Error
  • Kistar
    • Apr 2025
    Ok, this is the second time I've come across this problem. When printing (from a Mac, using InDesign, only with these 2 particular files) nothing happens. When I go over to my PC, I open Command Workstation to see if it shows up in the queue, and it does, but the line is pink and when double clicked, it says
    %%[ Error: syntaxerror; Offending Command: --nostringval-- ]%%
    Any clue what this means and how to fix it?
    Thanks!
  • B0265
    • Jan 2007
    • 718
    You might find some useful info here:
    Troubleshoot PostScript errors
    • Kistar
      Beautiful, thank you!!!!
