di 2010 "add toner"
  • euro scott
    • 127
    di 2010 "add toner"
    after installing new toner machine is still displaying "add toner". have tried repowering machine with no change in symptom. copy quality looks great. could it still be a developer issue? thanx
  • ni311
    • May 2008
    • 658
    Is the toner hopper working? Can you find out if the toner bottle is actually turning? Is it making any weird noise?
    I believe the bottle was forced in and the toner hopper is broken.
    Konica Minolta Error Codes - Explanations and Solutions
    • brent
      • Nov 2008
      • 1212
      my bet is also the toner add system in the back. haven't had to do one for 4 months. I am sure it will be my turn soon..
      brent
      • fixthecopier
        ALIEN OVERLORD
        • 4714
        If the bottle was put in wrong it will bend the shaft that rotates the bottle. Pull the covers off the toner bottle and gear pack and watch it run. Sometimes the gear that drives the auger to feed toner to the IU is not engaged.
        • euro scott
          • 127
          determined that it's something in the gearing but to get the finisher out looks to a sob, what's the best way to pull this section from the machine, i see you mentioned from the rear but when we looked at it from the front looked better, pulled it into the shop and took a loaner so we bought a little time.
          • TheOwl
            • Nov 2008
            • 1732
            Make 100% sure that the right toner has been put into the machine. The wrong toner bottle will cause similar issues to what everyone else is talking about ie. bent shafts and broken gears in the toner hopper.
            To get the finisher out, you will find a little black square behind the front door of the finisher near the bottom. Press this and the whole finisher will then slide out.
            • fixthecopier
              ALIEN OVERLORD
              • 4714
              If you can not find the black square, just pull real hard on the finisher trying to slide it forward, and the hook will let go.
              • euro scott
                • 127
                i have not been able to locate the black square, and pulling foward had not yielded any better result. does anyone have the manual availible?
                • mo0651
                  • 1054
                  The manual would have you disassemble the finisher. Open front door. Locate caution tag inside cover. Below that is the slot where the door actuator goes through to tell if door is closed. get down on hands and knees and look below that. You will see a screw for the cover and a square hole next to it. Insert screw drive in that hole as you pull forward on finisher. whole finisher will slide out.
                  • euro scott
                    • 127
                    got it now thanx
                    • euro scott
                      • 127
                      looks like severe damage to the toner bottle drive
                      • euro scott
                        • 127
                        can someone help me with part numbers? i need the main frame with the shaft and the white gear with the spring on it. thanx
                        • eg101
                          • Jan 2005
                          • 131
                          It comes as an assembly now - updated, P N 4030-0788-00.
                          • brent
                            • Nov 2008
                            • 1212
                            just replace that assembly. don't order the case and gears. because it is one tough deal to replace all those gears and parts. and then you want it to work right after you spent 2 hours on it right? just replace the assembly...
                            brent
                            • fixthecopier
                              ALIEN OVERLORD
                              • 4714
                              brent is correct. If you have never done one, it can be a bitch. It will only cost $30 or $40 more for the assembly.
