MINOLTA Di550 code C13-F5
  • Apostolis
    • Jun 2008
    • 20
    Hi
    Does any have experience to this code?
    I have 2 units with the same problem
  • Cantechman
    • Nov 2008
    • 228
    It is related to the printhead....turn off and on to reset. These are the instructions.
    C13F4~
    C13F8
    C13FAB
    C13FC
    1. Reset the malfunction.
    2. If the same malfunction persists, change the PH Unit.
    3. If the same malfunction is detected again, change the PH Unit.
    4. If the malfunction is detected a third time, change Image Processing Board.
    • Apostolis
      • Jun 2008
      • 20
      Thanks Cantechman,
      I know this instructions from the serv.manual, but I need certain
      special knowledge from somebody that has faced this code.
      Thank you
      • Kmdurrin
        Copy/Print/Network Tech
        • Dec 2008
        • 132
        We had a machine with this code. It turned out to be a bad PWB-B. Have you checked the boards (PWB-B and PWB-C)?
        Parts: Its what your copier craves!
        • Apostolis
          • Jun 2008
          • 20
          Thanks kmdurrin
          Yes I have replace the PWB-C but nothing.
          You know if afterwards the replace of PWB-B they are importants some
          adjustments?
          • Kmdurrin
            • Dec 2008
            • 132
            After replacing the board, we did a simple LD bias adjustment and the machine worked fine. Have not had this code come back yet.
            • Apostolis
              • Jun 2008
              • 20
              thanks again
