C450: Setting default paper size in copy mode?
  • siradlib
    • Jun 2008
    • 23
  • time2fly
    • Jul 2008
    • 134
    Read the users manual or go to:
    Service & Support | Konica Minolta Business Solutions, U.S.A., Inc. to find the info your looking for. Good luck
    • lucky13
      • May 2008
      • 125
      push the panel reset button to clear any settings left by previous users set your paper selection to auto press utility/counter button then press user mode then copier settings then default settings ,it may already be set to current settings thats ok just push it again then push ok and exit all the way out push reset button and should hold your settings
      • siradlib
        • Jun 2008
        • 23
        @lucky: Thanks a million, this did the trick!
