Konica Minolta C350 C-0501 Error
  • shanorto
    • Aug 2025
    This machine was taken in on trade, I don't have a Service manual. I've learned that this is a Fuser error. Any way I can reset this . I've tried reseating the connectors and restarting the machine. Any help is much appreciated.
  • jprecht
    • Dec 2008
    • 104
    reset code
    the first thing i would try is to open the front door and to the right of the blk toner is a gray cover remove this (2 screws) you will find a service pcb with a trouble reset button. try this and we'll go from there. jp ps c 0501 is a pressure(fuser) problem will likely have to change fuser units.
    IT IS BETTER TO REMAIN QUIET AND BE THOUGHT A FOOL
    THAN TO SPEAK AND REMOVE ALL DOUBT
    • shanorto
      Thank you, JP. That was what I needed. Much appreciated.
      • jprecht
        • Dec 2008
        • 104
        k/m 350c
        No problem. have several of these out there they are pretty good boxes. they make a heck of a print from the fiery. have several trix to bypass counters let imon know if i can help you further. jprecht
