Not getting an error code, but control panel very slow, is this a memory issue? How can I fix? Thanks
Bizhub C500 control panel very slow, sometimes unresponsive
Tags: accessed, bizhub, c500, control, control panel, lef, panel, slow, touch screen, unresponsive, verification
albasoul06
1- Enter the Key Operator mode, by turning the machine ON, while pressing the Help key7-Turn the machine OFF to store the adjustment. Turn the machine ON and check the operation of the touch screen.
2-Touch selection [10. Control Panel Adjustment] on the touchscreen to display the control panel adjustment screen.
( If the touchscreen is so far out of adjustment that there is no response when touching #10, the control panel adjustment can be accessed by touching any numeric key on the 10-key pad) . Two plus signs [+] should be visible on the screen.
3-Touch the + at the upper right lightly with a touch pen or something with a round tip as a pen.
4- Ensure that the X coordinate and the Y coordinate displayed in the message area fall within the standard values displayed on the second line. The values are in hexadecimal if the values are not within the acceptable parameters, repeat Step 3 .
5- Touch the + at the lower left, repeat the process used for the upper right coordinate
6- As verification of a correct adjustment, touch the Check keys at the upper and lower right corners. A beep tone should be heard. If a beep tone is not heard, repeat the adjustment.
albasoul06
2-Touch selection [10. Control Panel Adjustment] on the touchscreen ( If the touchscreen is so far out of adjustment that there is no response when touching #10, the control panel adjustment can be accessed by touching any numeric key on the 10-key pad ). Two plus signs [+] should be visible on the screen.
3-Touch the + at the upper right lightly with a touch pen and check the coordinates displayed in the top line at the top of the screen.
4- Check that the X coordinate and the Y coordinate displayed in the message area fall within the standard values displayed on the second line. If the values are not within the acceptable parameters, repeat Step 3 until the values are acceptable.
5-Touch the + at the lower left and repeat the process used for the upper right coordinate
6- As verification of a correct adjustment, touch the Check keys at the upper and lower right corners. A beep tone should be heard. If is not heard, repeat the adjustment.
7- Turn the machine OFF to store the adjustment. Turn the machine ON and check the operation of the touch screen.
