C352 with Fiery IC-406
  • Taminol
    • 171
  • Andyrsv
    • Jun 2008
    • 59
    Hi. Had the same thing with a 450 and a firmware upgrade on the machine, not the Fiery, fixed it. For other ideas check out the replies I had to the thread that I started.
    • TheOwl
      • Nov 2008
      • 1732
      Print out a Conifg Page and look for the following setting.
      Network Setup - Services Setup - Web (something or other, I can't remember exactly what it is called)
      Make sure that this is turned on. If it is set to off, then the Fiery is denying web interface access.
      • Taminol
        • 171
        Thanks for your reply.
        I just looked at the config report.
        Network Setup / Service Setup / Enable Web Services: Yes
        Oh well, was worth a look.
        • Taminol
          • 171
          Thanks for pointing me to your original thread
          I'll checkout what level they are at and upgrade as necessary.
          • kmcopier
            PSP
            • Oct 2008
            • 183
            Do you get ip socket error?
            • Taminol
              • 171
              No, it just doesn't display the page.
              The usual Internet Explorer message about not being able to connet...blah blah blah.
