Di2510 dead?
  • OutlawTorn
    • Aug 2008
    • 189
    Di2510 dead?
    Good day to you all, I am having an issue with a Di2510 copier. Called out to it and I arrive and its dead - nightmare. When I turn it on I can hear the fans starting up, but thats it - nothing else happens and I have nothing on the LCD screen. Oh dear.
    help?
    thanks in advance.
  • jprecht
    • Dec 2008
    • 104
    dead
    time for basic power supply work get your meter out and ck your fuses on dc power supply if ok then suspect boot problem. may have to swap out with known good parts. ck your boot rom, and hdd or swap controller board
    kiss it first.
    good luck jp
    IT IS BETTER TO REMAIN QUIET AND BE THOUGHT A FOOL
    THAN TO SPEAK AND REMOVE ALL DOUBT
    • JOSH
      Have you tried to make sure that the sub-power swith is turned on on the side of the display. May have to power main switch off then hit the sub-power swith.
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        I think if I remember correctly, change the MFB-3 and reflash the firmware.
