C0BA0 Finishing option Elevator drive malfunction
  • deannasockman
    Still Learning!
    • Jul 2008
    • 29
    Minolta 3102. Any ideas on what I can check? I have looked at everything on this finisher.
    According to my husband, "You're pretty smart for a girl."
  • Si@danwood
    • Mar 2008
    • 154
    Had a 3510(fn-117) do this to me only this past friday.Symptoms were that finisher trays initialized,then initialized again then threw up code!Turned out to be the screws holding the middle tray had come loose causing the tray to shift slightly and thus not making the home position sensors near the exit rollers!!!.. Si
    • deannasockman
      Still Learning!
      • Jul 2008
      • 29
      Where are the screws located? I'm desperate........ need this job run by Wednesday.
      • mitchl
        • Apr 2007
        • 501
        Deanna what model finisher is it, the FN-116 or the FN-8? Do the trays move at all when you turn the machine on?
        • Cantechman
          • Nov 2008
          • 226
          It soulds like a exit tray is not seated properly. Just double check the screws (2 for each tray) that holds the exit trays of the finisher. Make sure nothing is bent, etc. It is usually something minor like that.
          • deannasockman
            Still Learning!
            • Jul 2008
            • 29
            Thank you. I will check that asap.
