I have a machine that was just not booting up. It would stick at the Minolta emblem. I flashed it and got the conversion up error for the hard drive, but the screen was not functionable. I switched all boards, nothing. I switched NVRAM and it worked, I turned off and on, now doesnt work. I messed up another machine I took the NVRAM out of to test it, so now I have two down machines. Put new NVRAM in. Goes to planets screen. When flashing, it doesnt update the Scanner. Turned on with Utility button down, goes to Trouble Reset after showing hour glass and planets, but the screen doesnt work to activate the trouble reset. Screen works when loading firmware. Also loaded the NVRAM reset via flash card. Today I just replaced the NVRAM and MFP board. Still nothing.
WHAT COULD IT BE??????
