7145 Scanning
  • joneze
    • Aug 2007
    • 128
    7145 Scanning
    Hi,
    Its been a long time since i configured one of these machines. Everything is working except scanning it works but each time the user needs to enter the reply address. I have set the machine address within system setting but it does not seem to pick it up for scanning.
    Any ideas?
  • mrwho
    Major Asshole!
    • 4288
    This might sound basic, but did you configure the SMTP server?
    Mascan42
    Ibid
    • joneze
      • Aug 2007
      • 128
      Hi,
      Yeah i did the scanning does work but you have to put in the reply address manually everytime.
      Cheers
      • mrwho
        Major Asshole!
        • 4288
        Did you put the email address in the field reserved for the machine operator?
        Mascan42
        Ibid
        • joneze
          • Aug 2007
          • 128
          Hi,
          I have entered the Machine email address, but where do i enter the key operator email address?
          • mrwho
            Major Asshole!
            • 4288
            Try this:
            SOLUTION: To configure the email address, perform the following:
            1. Using the IP address of the NIC card browse to the utility page.
            2. Select Network Setup.
            3. Select E-mail Send (SMTP) Configuration.
            4. Enter a valid email address in the Key Operator Email Address field.
            5. Enter the default "0000" password, or if a Key Operator password is set on the main body, use
            the Key Operator password.
            6. Select Apply to confirm the setting.
            7. Power the machine OFF/ON.
            Note: The Enhanced Security mode must be OFF to browse to the NIC.
            Mascan42
            Ibid
            • joneze
              • Aug 2007
              • 128
              Try this:
              Thanks for your help. That worked. So is that the only way to set the Key Operator email via the web interface?
              Cheers
              • mrwho
                Major Asshole!
                • 4288
                I don't have one of those machines handy, so I'm not sure, but I'd guess not - it's probably buried in one of those options in the operator mode - maybe even under a different name!
                Glad it worked!
                Mascan42
                Ibid
