PI 47002 on a Windows 2000
  • poz31
    • Aug 2006
    • 86
    I set up an ftp on a pi 4700e with the ftp utility everything work ok
    I check basics
    On server set up a folder, shared (folder on c :\)
    From workstation checked ftp on server (ftp 192.168.13.2)
    Did requested login and password and it logged ok
    Port 21 checked
    Since this is the server, is there a setting different as the workstation (server by the way is 2000 ftp utility gives me an error for 2003)
    Id did try with IIS with no luck either
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Windows 2000 server has it's own FTP capabilities (as do most servers)which I would recommend you utilize that rather than trying to use the Konica Minolta utility. Now this is something that should only be set up by the network administrator.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • poz31
      • Aug 2006
      • 86
      Pi 4700e on windows 2000 server
      Thanks....
      yes it has that option but he requested no to set to FTP trough the server......They just to have a ricoh ang since the scan from 50 to 80
      pages at once ... the FTP server uses a lot of resources......and that is why they do not want the ftp server.......Since I was able to connected to a workstation they are loking to have the saem set up but in the server.....
      • pepper38_cnd
        • Aug 2005
        • 1075
        If you run the win 2000 ftp server utility or the KM ftp server utility require the same resources. But if you do it from the server itself, you don't have to worry about the server blocking the port and the Administrator has the ability to manage it.
        • buster68
          • Nov 2008
          • 181
          To my knowledge, the KonicaMinolta FTP server is only a client based application, it will not work on an actual server, since servers usually already have FTP services loaded. We've tried using the KM FTP utility on servers before and have never had success with it, never fails on a client workstation though.
          • TheOwl
            • Nov 2008
            • 1732
            M$ IIS FTP services aren't installed as a default when running up a Windows server. This has to be installed lated if it isn't selected on installation.
            Read through this doco that I setup for my guys a while ago and see if it helps with your issues.
            Microsoft Internet Information Services.doc
