di2510f PC fax
  • ck1
    • 485
    di2510f PC fax
    can show me hot to setting the PC fax for Di 2510f thanks .urgent !!!!
  • ck1
    • 485
    help ! teach me how to setting for PC fax .
    • rasman67
      first you will need to have the SU-3 installed in the copier, next you will need the software for network scanning. You will also need to set Gateway TX to "YES" . It's under Admin 2, Network, Scanner Settings.
      After software is installedyou will need to do the setup.
      • ck1
        • 485
        thanks for reply. it work ...
