I follow instructions on this board to turn off I/u life shut off and now am getting the message "power on authentication device"
C450 error
Do you have a Paycon or any other authentication device connected to the machine?' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation! -
Souds like you set the WRONG software switch or bit. OUCH. only fix would be to reset the switches if you can find the one you mistakenly did. not sure if a Total Clear will reset the SW on that machine or not????
You basically told the copier that a coin-op device is going to be attached to it. I suppose you could look that up in the service manual and check those switches and make sure they are set to default and NOT for a coin-op.
Hope this helpsComment
Enter the billing setting (check the service manual) and turn off any authentication device (key counter, vendor 1, etc) that you see there.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
