HP LASERJET 9850MFP FIERY RIP with Minolta Bizhub pro C500
  • 21043
    • 63
    Hello!
    can i plug HP LASERJET 9850MFP FIERY RIP (on photo) to Minolta Bizhub pro C500?
    i have another CF5001 with it's own rip, and this rip looks like 9850MFP FIERY RIP, and as i know 9850MFP it is re-branded C500 (8050, C500...).
    regards,
    Andrey.
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    That is a good question! Can you get a config page out of each of them while connected to their intended product and compare them? This is something I would be interested in knowing as well.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • 21043
      • 63
      i can get it only from my fiery S300 (with Minolta CF5001).
      i plan to buy C500 without RIp and buy 9850MFP FIERY RIP for it - so i cant get this page from 9850MFP FIERY RIP.
      • mrwho
        Major Asshole!
        • 4299
        Unless someone that already tried it replies here, I guess you'll only know when you try it. It's possible that it works without changes, or even if you try to flash the IP-901 firmware on it, but it's also possible that the hardware is keyed so that it will only work on its own machine.
        Mascan42
        Ibid
        • mrwho
          Major Asshole!
          • 4299
          On a side note, I once had to use a Minolta Fiery on a Konica machine (the pi7200 of the Minolta version of the Konica 7272) and the only way to go was to flash the Konica 7272 with the Minolta firmware.
          Mascan42
          Ibid
          • 21043
            • 63
            i write to Fiery tech support - they actually don't know, will it work or not :-(
            • mrwho
              Major Asshole!
              • 4299
              Can't say I'm the little bit surprised. They make good products - but the tech support is flaky at best.
              Mascan42
              Ibid
