di 550 power on problem
  • laxman
    • Jul 2009
    • 10
    Hi,
    when i switch on this machine it refuse to (some times it does) every time i can hear the click sound of relay in power supply but no display.
    One of friend told me to check for dry sold on power PCB, i tried that it worked for few on off and then again came to same position.
    can any body help me on this?
  • Hansoon
    • Sep 2007
    • 3390
    We once had an issue with the main relay RY1 causing similar.
    Hans
    • WetPaper
      • 14
      Could be a problem with upper fuser thermistor failing. Try removing fuser unit then power up machine. If it powers up, then you might need to replace the upper thermistor.
