C6501 banding in cross direction
+ More Options
Posts
  • edmund
    • Jul 2009
    • 29
    please help!!!has someone sorted this problem on the C6500 and C5601 .
    BANDING IN THE CROSS DIRECTION.
    we have replaced alll the boards including HV1 and HV2
    We have replaced drums all four,transfer belt and transfer rollers
    ther ewas a thread posted on this same problem before ,but no concrete solution
    Please can someone help
  • mrwho
    Major Asshole!
    • 4290
    Can you share a scan of the problem with us?
    Mascan42
    Ibid
    • Si@danwood
      • Mar 2008
      • 154
      Some scans would be good for us to evaluate but the highlighted section seems you may have the answer you may not have wanted to hear.Si
      • edmund
        • Jul 2009
        • 29
        I donot have a secure server here so it is a bit difficult sharing this scan I will try and send on today
        More info. We ran prints on our two showroom machines C5501 and C6501, thet are both both giving us the same banding condition
        We run test prints in the technical mode test prints,set all four colours to 100 halftone and test pattern 53
        we do the prints on line1 and the bands appear on dot1
        I will keep you posted if we found anything new
        • random
          ahhhh is this prominent in yellow? If so you need to turn the special screen dipsw for DOT off. It was designed to fix one problem but actually causes pretty horrfic banding.
          • edmund
            • Jul 2009
            • 29
            thanks for the advice
            Can you tell me what dipsw it is.Ihave checked the manual and the only one that indicate anything to do with changing screens is dipsw2 bit 5
            I
            • edmund
              • Jul 2009
              • 29
              Can you tell me what dipsw it is.I have checked the manual and the only one that indicate anything to do with changing screens is dipsw2 bit 5
              I have sent this info to Japan hopefully they will reply and when they do I will definately let you
              • edmund
                • Jul 2009
                • 29
                Answer From Japan
                subject
                yellow banding on dot1
                This color apearance is totally "normal" behavour on this type of engine.
                It is because under dot 1 the laser writes under a different angle and therefor yellow banding will occur ONLY on dot 1.
                A very good workaround is the following:
                - Utility
                - System settings
                - Expert adjustment
                - Quality adjustment
                - Custome screen
                Now, select DOT2 -> TYPE2
                After the settings are changed, perform all instructions on the same screen.
                Next step is to callibrate the engine. I will reccoment to callibrate all screen types.
                After engine callibration, callibrate the controller and here as well, make sure you callibrate DOT2.
                Before you send the print job, select DOT2 type in the driver, or send the printjob to the hold que and change the screen settingin the job properties.
                Please let me know your results.
                Kind regards,
                as per this answer we have to user dot 2
                and this will close this query
                thanks alot for your input
                • random
                  set dipsw 3-0 to 0 for dot
                  • edmund
                    • Jul 2009
                    • 29
                    thanks alot random I will try this dipsw
