konica 2230 error message 36-01
  • sohail molvi
    • Jun 2025
    I had Konica 2230 and I have change the fuser then when I turn the machine on I get error massage 36-01
    Can anyone help me to solve this problem ?
    Or are anyone have the server manual for this machine?
  • mrwho
    Major Asshole!
    • 4299
    I don't know that particular model, but a google search leads me to believe it's a sister machine of the 3240. So, try this:
    To clear fuser codes, perform the following:
    a. Access the 25 mode (power the machine OFF, hold down the 2 and 5 keys and power the
    machine ON).
    b. Select [1: Software switch set mode?] and press the OK key.
    c. Set the software switches as follows (press the OK key to enter the new data):
    3-5 to 0: resets F34 code
    3-6 to 0: resets F35 code
    3-7 to 0: resets F36 code
    d. Power the machine OFF then ON to exit the 25 mode.
    Mascan42
    Ibid
    • sohail molvi
      thank you "mrwho"
