C351 - how do i get into Service Mode?
  • mbakken
    • Jul 2025
    I have a C351 and started a HDD overwrite yesterday. 12% into it, i lost power for a moment. It now has the C-D010 code that i have seen mentioned in the threads. It references going into Service mode which i dont know how to do - and since the overwrite was not even completed i dont know if the logical part will work?
    I called KM and they are telling me its a minimum of $160 to walk in the door and then $130 per hr...
    Currently the machine is not working in any capacity and I at least need to get it back printing- HELP!
  • jeroen2005
    • 48
    Press utility button -counters- cont details- stop -0-0-stop-0-1 then your in.
    • mbakken
      So here is what i tried - hit utility/counter button. then hit controller details button. then up comes the error message window. i hit the red stop button. then hit the 1 then 1 again. then stop button. then 0, then 1 again. nothing changes on the screen, still just see the error window. Besides the C-D010 there is also the code 35C-KM...
      • pepper38_cnd
        Field Service Manager
        • Aug 2005
        • 1075
        Just out of curiosity, what was your reason for doing a HDD overwrite in the first place?
        Also I believe the Hard Drive management is also available from Administrator Mode if what you are wanting to do now is reformat and start over.
        Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
        Now into Ip TV KODI Boxes
        • mbakken
          i am planning on selling it soon and was told to do this so all old data is erased? NO idea if this was a smart move or not.
          • mbakken
            PROBLEM FIXED
            thanks for your help on getting into service mode! I was able to get in and then followed the instructions from a diff thread on how to fix error C-D010 (thanks to Laserman06).
            • pepper38_cnd
              • Aug 2005
              • 1075
              I'm glad to hear it worked out for you, and I am really glad you looked up previous threads ( so many just ask with out doing the research ). Good work and thanks for letting all know it worked for you.
