c450 network problem
  • bronxizzy
    • Mar 2008
    • 23
    had an it guy go to the network settings and input ip address had him turn off machine when turned back on network never came back. can't even find the controller in system 2. any help please
  • pajeroid
    • Jul 2009
    • 130
    How long did you leave the machine for? Sometimes it takes a while for the Controller Detail and Network Tabs to appear after changing settings.
    • bronxizzy
      • Mar 2008
      • 23
      its been a couple of days.
      • mrwho
        Major Asshole!
        • 4299
        At first, I'd guess you'd need to reinstall the Fiery software, but if you can't find the controller setting in service mode, things get tricky...
        So, I'd first try a firmware upgrade (or reflash, if it already had the latest version). Then, if the Controller option reappears, check if you have "Controller 1" selected for the Fiery (the internal controller is "Controller 0").
        Good luck!
        Mascan42
        Ibid
