Jam 32 Konica 7055
  • BGCTC
    • Aug 2025
    Jam 32 Konica 7055
    I have done the steps on the "guide" option. Open 1,2,3, but there is no evidence of a paper jam anywhere! The message keeps coming up as "Jam Code 32-00". Thanks for some help!
  • minimerlin
    • 851
    Is this on single copy or multi runs. It sounds like you may have a sensor problem. I would look at the fuser exit area.
    Please do not PM me without asking first.
    • BGCTC
      I think it was for a multi-copy project. The top drawer (#1) also won't go back in, it is hitting something (unidentified). Don't think its related because I was able to make copies even with the drawer pulled out.
      Thanks for the suggestion.
      • mrwho
        Major Asshole!
        • 4299
        DESCRIPTION: J32-00 at power up.
        CAUSE: Fixing paper exit plate upper (p/n 55TA53080) is causing the actuator for PS27 to bind.
        SOLUTION: Reform the paper exit plate upper so that the actuator for PS27 moves freely.
        Mascan42
        Ibid
