Hi guys,
There are posts on the forums that talk about replacing a fuse to reset the counters for the transfer belt and the fuser. Instead of having to rechip each IU is there a fuse that can be used to reset/ignore all the counters on the image units? Is that what this fuse, KONICA MINOLTA (Compatible) Chips - Reset Fuses 0251.062MXL
Thanks in Advance!
Thanks in Advance!
