Bizhub Pro C6500 / C6501 / 65hc.
  • jma676
    Expert Tech
    • Mar 2009
    • 324
    Hello i`m looking for Firmaware version Historial to the Bizhub C6500 / C6501 / 65hc.
    and i nedd doc for GCA-30 / G00-40. other, i need G00-30 / GMG-40 / G00-50 / G00-60 Firmaware and doc.
  • Si@danwood
    • Mar 2008
    • 154
    Why do you need the different versions? As long as the Fiery is on latest version ver 50 zip should do fine!Get in from your normal KM website as usual there should also be a revision history there as well...Si
    • jma676
      Expert Tech
      • Mar 2009
      • 324
      re
      Ok i need revision this versions for view all error solution.
      I start my Bizhub Pro C6500 (IC-408) With G00-30 Firmaware version and Version Up with G00-40 / G00-41. And never can find solution Definitive of problem C22xx, C4850 and other image Problem, anyway i resolve this problem with adjust my bizhub but i want solution this problem.
      I understand that these versions are solved or at least reviewed several of these problems.
