I have a C352 Konica Minolta Bizhub. I am trying to change the Fax Header information. I access the fax header settings and changed them to my new header. Yet, the old header still transmits when I fax. I go back to the settings and it shows the new header yet it still transmits the old header. Is the old header embeded somewhere??
Fax Header for C352
Try this:
Solution IDTAUS0800213EN* Solution Usage
Description
When a fax is received, the header name is misspelled. When the header datais checked in Admin mode, it is correct.SolutionCAUSE:Incorrect settings.SPECIAL NOTE : Solution contribution by Gary Scimeca, Production Print/SSD
SOLUTION: Set each mode, Copy, Scan, and Fax, to factory default and reboot the MFP. When theMFP comes to Ready, input the correct fax header data.
To set the mode to factory default, follow the procedure below:
1. Select either the Copy, Scan, or Fax button.
2. Press the Utility button.
3. Press User Setting.
4. Press Initial Setting and select Factory Default.
5. Press OK.
6. Press Close (x2) to exit the mode.
I have a C352 Konica Minolta Bizhub. I am trying to change the Fax Header information. I access the fax header settings and changed them to my new header. Yet, the old header still transmits when I fax. I go back to the settings and it shows the new header yet it still transmits the old header. Is the old header embeded somewhere??Comment
