Konica 2125
  • LandE1
    Konica 2125
    have a code of f45. Machine will turn on but nothing else. Any suggestions we can do ourselves?
  • JustManuals
    • Jan 2006
    • 9838
    Yes, open the phone book and look for a Konica copier dealer, call them up make an appointment, mix up a pitcher of margaritas, start sloshing them down and wait for the technician to arrive. When the tech gets there, explain the problem and go back to those margaritas.
    HtH
    Paul@justmanuals.com
    • Col. Buckshot
      Konica 2125 - the copier that time forgot.
      If your code is a F45-1 thats a lens motor code. Watch the lens carriage when you turn on the copier - it should move right and left to set home position. The motor that drives the lens carriage has a small white gear. That gear spilts, you can fix it with thin super glue. You have to remove the control panel to get to the motor. Let me know if you need more detailed instructions.
      • donaldtex
        • May 2009
        • 43
        What is lens?
        Yes, sir. I strongly suggest you to call a pro, these machines were a real headache-maker, don't forget the carriage cables getting tangled, that also causes these codes...
