Bizhub_600 / Now warming up ready to scan.
  • ravikumarj
    • Apr 2007
    • 49
    Copier symptom in the panel " Now warming up . Ready to scan"
    Heater is getting on and the temperature attaining ready,
    for the benefit of doubt interchanged with with good working fusing unit.
    But symptom remains the same.
    The copier green button shows ready. and ready for scanning, after scanning completes no print is taken place.
    Cleared all the job memmory.
    Still shows "NOW WARMING UP."
    Any reset procedure??
    advance thanks for tecnical help.
    RAVI,
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    It is possible the sensor for density that is under the drum blade is dirty. It will not code, it just sits there. Pull the drum and clean the sensor.
    • emujo
      • Jun 2009
      • 3009
      Seen this with Key Counter turned on in service mode, but counter was removed for service work. Scan is accepted but no key counter inout to allow prints. Emuji
      • suomi
        • Oct 2008
        • 155
        tcr.....
        change drum & developer
        • ravikumarj
          • Apr 2007
          • 49
          I found toner in the ATDC sensor, cleaned Drum unit. now working fine. Many thanks.
          I have few copiers of Di 7210, but I never found this kind of symptom that copier warming up indication.
          I once again thank you for all your coordination.
          Ravi.
