bizhub c500 sc28-04
  • doomblack
    • Aug 2009
    • 12
    bizhub c500 sc28-04
    got an error code for c500, started as a sc29-06 cleaned the sensors and now its a sc28-04 something with the coronas i presume, any advice ?
  • Kmdurrin
    Copy/Print/Network Tech
    • Dec 2008
    • 132
    CAUSE: Abnormal charge. Related codes to colors are as follows:
    28-01 = yellow
    28-02 = magenta
    28-03 = cyan
    28-04 = black
    SOLUTION: In order, perform the following:
    Switch Charge Corona with one of another color.
    Change indicated color Charge Corona wire.
    Switch Drum Potential Sensor (p/n 65AA-2282) with one of another color.
    If the problem persists, replace HV-1 (p/n 65AA 8401 0).
    Parts: Its what your copier craves!
