C250
  • big jase
    • Jul 2008
    • 136
    C250
    I have a c250 that is good quality on copies but when you print the image is too red as though all image has had too much magenta.Have you seen this before as I suspect board but what to exhaust all other avenues before ordering due to costs!
    If at First you don't succeed remove all evidence of ever trying!
  • apache_cat
    I.T. Tech
    • Jul 2009
    • 81
    Have you done a colour calibration. Konica calls it gradation just cant remember which menu it is in.
    • strider5555
      • Jun 2008
      • 96
      Gradation adjust is in tech rep mode under image adjust. First do an initialize and stabilize, then do gradation adjust. Select gradation mode, press start. A test pattern wil print out. Place on glass and close original cover or df. Press start to scan the test pattern. Repeat these steps to scan each new test pattern 3 times each for gradation, resolution and high compression mode, for a total of 9 scans. When complete,exit tech rep mode and turn off the power for 15 seconds and restart. The gradation adjustment and stabilization settings arre also available in administrator mode under expert adjustment.
      • backspace
        • Jul 2009
        • 54
        also check in service mode under state confirmation setings for laser and corect them if need.
        It must be about 0 +-5, and K about 0 +-1.
        • big jase
          • Jul 2008
          • 136
          Thanks all
          Did reset & stabilazation then gradition set up ,worked a treat
