Hi all,
can anyone help me on this? i found that the default network setting is not always same for different models. this cause a lot fo trouble as i need to try different setting each time i need to setup an SMB scanning.
below is the default network item that i always key in:
ip address = given by customer
subnet mask = given by customer
default gateway = given by customer
dns server adress = given by customer
dns domain name = uses back the factory default
when creating the address book for SMB, my customer request to use the local computer admin id and password for login. my problem is some of the machine failed to scan when i key in the dns domain name. some also fail when i use the short pc name for scan destination. instead i have to use the full pc name.
this problem only happen when i use the local admin id. if the windows login id is use no problem happens. please help
p/s: my customer doesn/t want to use the windows id because thier password expires monthly.
very clever.......
